best 410 lift hyd cam for 7000 rpm
  • stealth-hp
    • Jun 2012
    • 14
    We have a max of 410 lift at the valve which is approx. 250 lobe lift this is a stock rod 7000 rpm needs to be a hyd flat tappet stock head & 350 carb what are your thoughts on a good race camshaft
  • t9racing
    • May 2013
    • 19
    Is it .410 after lash?
    • stealth-hp
      • Jun 2012
      • 14
      its a hyd with a max of 250 lobe lift which = approx. 410 lift
      • t9racing
        • May 2013
        • 19
        Duhh that was a terrible question should have read ur post a little better check out the RACe engineering site they have one perfect for u I believe its the 242
        • stealth-hp
          • Jun 2012
          • 14
          great thanks
          • Big E tech
            • 104
            We have one at Esslinger that we call a .400" lift rule cam. It would be my recommendation. Let me know if there's anything else I can help you with.
            • return to dirt
              • 1008
              brian, why does the roller cam valves use a .400 tip and the non-roller use a .550 tip? thanks.
              olin
