main beaing Help
  • lazer16
    • 79
    main beaing Help
    I have some main bearings that came out of a 2.3 cant find anyone that has them they are clevite the number on the back of them are 3546cp the center bearing has MB2613p I have not tried the race shops have to call the Monday
    thanks for any help
  • Dirtman29
    • 1690
    What date code is the block? And are the old bearings marked STD, .025, or .050 on them? You need the yr of the block and any parts store should be able to get you the right set.
    • lazer16
      • 79
      not sure of the year numbers on the side looks like RF E3ZE 5015 00 then it has 88 L02 and yes there stamped .25mm where would the year on the block be stamped thanks
      • TM 44
        • Jan 2009
        • 74
        E3 = 1983. D=70's E=80's F=90's The number after the letter is the year in that decade
        • car62
          • 1579
          E3 is the year code, meaning 1983, so it is large journal bearings.
          www.raceidaho.com
          • Dirtman29
            • 1690
            The .25mm marking means your crank has been cut once already.
