ranger flywheel????
  • 83fairmont
    • Apr 2014
    • 2
    ranger flywheel????
    I'm building a 83 fairmont for a mini stock class. I was wondering if a ranger 2.3 fly wheel will work with a 83 2.3 mustang/fairmont clutch and SROD 4 speed trans? thanks!
  • Dirtman29
    • 1690
    Yes but its way too heavy for racing, lots of guys use a 91-96 escort 1.9L flywheel, still stock but roughly 6# lighter. Bolts right up to a 2.3 crank but MAKE SURE you use shorter flywheel bolts. Your clutch should bolt right up also.
    • 83fairmont
      • Apr 2014
      • 2
      What size bolts would I use then? Advance sells a replacement 1.9 flywheel for around $65.
      • Dirtman29
        • 1690
        Same thread about 1/4-3/8" shorter than the OEM 2.3 bolts. The long ones bottom out & dont truly tighten with the escort fly making for a loose flywheel!
        • FATMAN
          • May 2008
          • 51
          Is the tooth count the same on the escort flywheel?
          Daniel #27 mini stock
          • car62
            • 1579
            the escort is 132 tooth count
            www.raceidaho.com
