my car is very hard to steer but dont want to give up the horse power for power steering.. it has quick steer.. what steering rack will make it easer to steer?
steering rack?
remove the steering quicknerNo matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
i run a rack from autozone that is 2.2 turns lock to lock..no pump,no quickner(already quick with that ratio).No matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
okay thanks.. got a rack from a friend felt good off the car but steering is still tight even with it on jack stands.. I thing the u joint is putting it in a bind.Originally posted by car62 View Posti run a rack from autozone that is 2.2 turns lock to lock..no pump,no quickner(already quick with that ratio).
www.raceidaho.com
Duralast Part Number: 64163
Warranty: Limited Lifetime
Application: Ford type (1 piece aluminum housing)
With sport steering (2.25 turns lock to lockNo matter how hard you try...you cant fix stupid!!!
www.raceidaho.com
Make sure your u joints are timed correctly on your steering shaft. It will make a big difference.
