Hi Leon. Can you run a cable? It would be a little hard to discribe how to build linkage. Someone here may have a photo or two of some linkage but it still might not be what you need. A cable is an easy way to go. Just my opinion.
Here is a picture of one I used to too build for my car using and Esslinger intake. If your carb is not turned 90 degrees you could connect the linkage directly to the carb and bypass the bell crank.
Thanks everyone. Ended up using cable, cut/moded oem bracket and it worked. Twisted end of race pedal and ran the cable to it. First practice this weekend, will see how it goes. Thanks, Leon
