How can you tell the diff between a 2.5 and a 2.3 externally?
  • dustball
    • Jul 2009
    • 4
    I'm supposed to look at a bunch of parts to buy tomorrow. I don't how you tell the difference between the two motors. Is there a different casting on the 2.5's? I don't know how to decipher(sp?) the date codes. Is that the only way to tell without takin the motor apart?
  • Dirtman29
    • 1690
    Ford part #'s begin with a letter, D= 70s, E= 80s, F= 90s, the 2.5L did not come out til sometime in the 90s I believe, so if the OEM part# starts with a D or E its most likely to be a 2.3L. The letter willl tell you the decade, the second digit (it will be a number) tells you the year, E6 = '86, or D9= '79 etc.
    On the 2.3L block, the # is located on the RF corner of the block just under the head. Ive never had a 2.5L so cant help you with that. Good luck, hope this helps.
    • 4b316
      • Mar 2010
      • 8
      The 2.5 block has a big"2.5" on the side of the block
      • scoobydoofletcher
        • Jan 2010
        • 30
        the way you can tell is probably when you get your doors blowed off it was probably a 2.5 motor
        • dustball
          • Jul 2009
          • 4
          Thanks forr the help guys. It hadd a BIG 25L on it as soon as i saw it. lol Thought that was a dead give away. Now i just need a small journal 2.3 block. thanks again.
          • Dirtman29
            • 1690
            Where are you located, I have a 2.3L engine, still OEM needs rebuilt. Just the pan, block, & a stock head. $75 would take it.
            • dustball
              • Jul 2009
              • 4
              I'm in northern california. I have 5 or 6 lg journal blocks that I can use with the spacers. I just wanted to try and find a block. On another note The 2.5 I got has tiny valve springs for the 7mm valve. Does anyone make an aftermarket spring for these?
              • soonersublime
                • Jan 2008
                • 995
                raceeng.com
                • JBV-HEADS
                  • 1202
                  If you are racing MRP that 2.5 head just won't produce enough power to run up front. I'm selling all my racing stuff so if you need something drop by Clay and Paquette in Yuba City. Call the shop first as I'm only in part of the time. Good luck,
                  Joe
                  Joe
                  tech@cpengineperformance.com
                  • dustball
                    • Jul 2009
                    • 4
                    Yeah I'm gonna be at mrp. I dont really wanna run the 2.5 head. Just tryin to put smaller guides and the 7mm valves in the D-port.
                    Thanks Joe. I'm only a few minutes from Clay and Paquette. What time and days are you usually there?
                    • JBV-HEADS
                      • 1202
                      I have no set time, I'm retired. Best to call 671-2091 and tell Chris you want to see me if I'm not there. Leave a number with him and we can set up something. Thanks,
                      Joe
                      Joe
