2.3 auxiliary shaft
  • r3tracing
    • Jul 2011
    • 224
    2.3 auxiliary shaft
    Any tricks to using a stock auxiliary shaft and making it live
  • Dirtman29
    • 1690
    Good bearings...I've always used stock aux shafts with a stock TFI dist. & never had any problems.
    • r3tracing
      • Jul 2011
      • 224
      We run the m86 oil pump and have heard of many people stripping the auxiliary shaft gears
      • TM 44
        • Jan 2009
        • 74
        high vol oil pumps can kill the gear and aux shaft. We use a stock oil pump and never tore one up yet. Stripped about 6 or 7 over a two year period with hi vol oil pump. Changed oil pump to stock 18 years ago, and no more problems....
        • r3tracing
          • Jul 2011
          • 224
          How much oil pressure do you have with stock pump
          • TM 44
            • Jan 2009
            • 74
            55-60 cold idling, 80-90 at full throttle and about 35 idling after racing.
            • 84Dave
              • 915
              Esslinger Engineering probably has a lot of good advice regarding the aux-shaft. Their experience is close to endless? -Dave-
              • r3tracing
                • Jul 2011
                • 224
                Tm 44 did you run bronze gear or stock gear on distributor shafr
                • TM 44
                  • Jan 2009
                  • 74
                  stock gear on the dist. and stock aux shaft
