Info on a head
  • TheBandit
    • 31
    Info on a head
    I have came across a head that has been untouched as far as machine work. Not sure of the year but it is a closed combustion chamber. But the difference is it appears it's a little more open than the standard closed we have seen before. Anyone seen this before or have any info on this. Thank you
  • crcltrakr
    • 293
    Any numbers on the head?
    JerryM
    • TheBandit
      • 31
      Does have ford stamped on it. There was something weird about the numbers on it. I'll have to check that out. I have heard that ford had some marine heads. I believe this maybe one of them. I will get back to you later. Me and my daughter are spending the day together today.
      • Foghorn
        • 293
        Find whatever numbers you can and possibly some photos of it.
        • TheBandit
          • 31
          He is the pic of the combustion chamber. Only numbers was M13 next to ford symbol
          • Old Rob
            • 1027
            It might be off of a forklift engine. Most of them used LP, natural gas for fuel.
            • CRP Racing Products
              • 3
              This was a limited run replacement head for Ford back in late 70's early 80's Very good head to run you can make really big compression #'s with this head. Too bad back east they've out lawed those heads😁
