I'm looking for a better flowing air cleaner base to bolt on my weber 5200 carb. I'm hoping to find something that covers the choke towers. I already have a k&n filter on the motor but stock base. Any suggestions were to find something would be great.
weber 5200 carb
Redline has a cold air filter set up that uses a remote filter. Webers do not like a filter/air cleaner lid to close to the top of the carb. Higher is better. I've used the two barrel triangle air cleaner from Edlebrock on the Webers with great rewards. You have to open up the carb hole to fit the Weber, but that's easy. The two barrel air cleaner is hard to find but Edelbrock still makes them I'm told.
