Pinto Tie Rod
  • knight54
    • Aug 2012
    • 64
    Pinto Tie Rod
    Anyone know of an inner tie rod that will work on a stock pinto manual rack? Ford nor do any aftermarket manufacturer does not make them anymore and need one?
  • TM 44
    • Jan 2009
    • 74
    Advance Auto- Driveworks part number--DW-EV117 $18.99
    Moog Tie Rod end- Part number--EV117 $38.99
    • pinto99
      • 6
      I think the EV117 inner tie rod is for the power rack and won't work on the manual rack. I searched a few part stores too and was surprised that I couldn't find any. If you can't find any you might have to look at a complete rack. I see one on eBay for 74.95 with free shipping.
      • TM 44
        • Jan 2009
        • 74
        I am pretty sure that they are the same. We have swapped these things around from rack to rack for a lot of years. The ones for the strut cars will work also. Some are a little longer, but it will work. There is a lot of adjustment for the outer tie rod. Some racks have a set screw that helps hold the inner threaded piece on and then some have a roll pin through them. You can make either one of them work.
        • Old Rob
          • 1027
          FYI; 71 - 72 racks are different. 74 and later are basically all the same depending on the manufacturer.
