what is a good base line set up for a mustang running on asphalt. 1/4 mile track tight corners medium banking . spring rates - caster camber and toe . any help would be very much appreciated.
mustang set up
We run on a 1/4 mile with tight corners, 18 degree banking. Our baseline is 1 degree left side 2.75 degree right side caster. 4 degree left side camber, 6 degree right side camber. 450 left front, 600 right front, 175 left rear and 150 right rear springs. and adjust from there. 1/8 th inch of toe out
thank you for the info, what cross do recommend starting with and do pre load the sway bar . also i have conflicting info on which side to put the adjustable link on.
Preload is going to depend on what size of swaybar you are allowed to run, atleast I have found that. At the 1/4 mile track we run, the rule says that you must not run any bigger than a stock 1'' bar. The setup that works for us there, is go to neutral on the scale and then preload 2 full turns on a corse thread link. On the other 3/8ths track we race, we can run any stock bar, so we run a 1-5/16th bar with 3 full turns of preload and adjust from there. On the quarter mile we usually end up in the 50.5 to 51 % of cross. Our adjustable link is on the left side.
