2.3L ford engune gurus, please help!!!
  • Dirtman29
    • 1690
    I know the cam card says .479 lift, intake lobe center is 108, exhaust lobes 110 or higher, SAE duration is 292. Im racing sat/sun this weekend & see how it does.
    Old rob what would you suggest for an exhaust, I have the schoenfeld 239V header, a ranger header & an OEM manifold. Ive ran all 3 with good results, using the stock ones at the bigger track I race at. Honestly I couldnt tell any diffrence between OEM manifold & ranger header. Stock bottom end I try to keep it under 7400 RPMs.
    • 1195
      • 86
      Exhaust is 116
      • Dirtman29
        • 1690
        Raced last nite & car ran great. Thanks for all the help!
        • 1195
          • 86
          Good job. Have fun.
          • Old Rob
            • 1027
            You will not see much difference between those. The best flowing manifold is the later model tri Y cast iron. Header from www.powerbyace.com with a 42" (from the junction of the 4 primary tubes in the collector to a large gutted muffler that displaces approx 340 cc's in size. Then if too loud a short muffler.
            Additionally as you change the cam retard/advance the compression reading will change.
