bought this car in boxes and have put it all together ran it friday well needless to saw not a good time.the way this ford ignition is wired just does not look right. its got the smaller cap with the module on the side of distributor with 3 wires cut and taped off. It seems like the timing isnt advancing and just dies out but runs great in garage. my question is does there need to be another box to advance timing? i can advance it while running and seems to run better but wont restart if stalled. thanks to all for any help
need some ignition help
With that setup there you have to set the timing at the total advance you are wanting. There is no mechanical advance in the distributor. So if you want let's say 36 degrees total advance then you have to set it at idle with your timing light at 36 degrees initial. It can make it hard to start (Especially hot). A lot of people use this distributor because it is simple and cheap. I would not personally use it but lots of guys do
