Can anyone tell me what honda long rod to run in a 3tc? Some details on what is needed to do to make it work? Please contact me @modified101@rocketmail.com
Thank you
I always ran 5 inch h beam . some tracks 8500 some 9000. rpm's , no need for longer rod . I quit running 89 mm pistons .went to 88 mm because later blocks start to weep under higher compression. had to start using kw block sealer
