If you wanted to run a 2.3 crank in a 2.5 block what would be the benefit? Other than crank trigger? Is there anything you would need to do? Are the 2.5 blocks bigger bore, taller deck or anything like that a long with a larger stroke?
Reason I'm asking is a guy at our track says he did just that? Our rules were lb per CC. So as we all think, he is just saying that so he can get away with running a 2.5 or the 2.8 stroker.
