Just checking on what fuel pressure to run. 2.3, Ford, Holley 500 CT carb, & electric pump. Not sure what other info you may need for this question.Thanks....
You don't need huge amounts of pressure, 5-6 psi. Too much pressure and you end up sinking the float. Volume is more important. We always ran a mechanical pump. If you are running an electric pump run it on an oil pressure switch.
