Spun bearing
  • FLYIN-9
    • May 2015
    • 83
    Spun bearing
    This may be a dumb question, but what would cause a spun bearing on the crankshaft? I'm just trying to learn, & see if I could have done anything wrong!!
  • 84Dave
    • 915
    Did you spin a main or rod bearing? Did you at least Plasti-Gage the clearances when you assembled the engine? Do you have an oil-temp gauge down in the pan? Did your oil-pressure gauge look OK at idle and across the rpm band? Were you running at least a 10W-40 good racing oil? 84Dave
    • dave41
      • 208
      spun bearing
      did you check clearance between sump pickup and oil pan. I always go 3/8"
      • let-r-eat
        • 2319
        Did you spin #1 rod bearing?
        BUCKLE UP NOW, YA HEAR?
