What is the best shocks and struts for a ford mustang dirt car thanks for your help
Shocks and struts
welcome backOriginally posted by ATOYOTA View PostPenske aluminum body rebuildable shocks and struts would be pretty decent. But the BEST would be some electro magnetic shocks but then those would run you about $10k each. but then that's the best and thats what you asked for.
www.raceidaho.com
I had good luck with the afco mini stock shocks and struts. Part numbers are 1040, 1041, 1042 and 1043 K series, depending on your application. They can be found from about $55 to $65 each. I know they may not be the best but I have no complaints with them.
On my fox body mustang I run a Lakewood suspension 70/30 Drag strut on the RF a standard monroe senseatrack strut on the LF and pro shock SS400A adjustable on the rear they have three levels of adjustment--easy up for quick weight transfer, conventional 50/50 valving, and tie-down for slow weight transfer on pavement or sticky track conditions. There are alot of strut and shock manufactures out there alot I think is personal preferance.Miller
