New to mod this year, been fighting a push on corner entry all season, everything we try to free it up doesn't work, just wants to go straight on entry. Suspecting that the rear master cylinder isn't working right. Saturday the front hubs were hot, the rears were warm. Is there any way to check it?
entry push
IMO I wouldn't get to distracted by the brakes. I suppose it depends on many things but if the car is setup properly it should be wanting to turn entering the corner without a lot of brakes. Are you running the RF shut off? assume the car has been setup properly close to the mfg. guidelines?
If you get on throttle before you have car turned in it will push, even with a car that is setup correctly. It does sound like brake bias needs to be adjusted to rear-will loosen up rear some.
Check the rear end alignment. I had this issue a while back and my housing was bent. I tried everything to free it up on entry and it was actually an alignment issue from a damaged part. Sometimes little things like that can get missed.
Drove a car like this once bias adjuster for front to rear was messed up even all the way adjusted to rear it still had too much front brake which will make any car tightBroc Burton
go.fast.crs@gmail.com
If its a old car the ball inside the brake pedal maybe jammed up. Or Like Broc stated it maybe out of adjustment. What size m/c front and rear and what size pistons on the calipers, have you verified they are all the same? RF shutoff available? More questions than answers right now. But like the other guy said the car should turn in reasonably well w/o the brakes, if you are donkey kicking the brakes to turn it you are losing speed. Probably should confirm that the pistons in the front aren't jammed up and that's why they are so hot.
brake bias is easy to check. when you pull on the track or even in the pits with 100 percent rear you should easily be able to kill your motor by slam the brakes and the car should tail out not skid the fronts unless your on slime etc.
Get some gauges and check brake bias. Then since you're new to this you better get familiar with using both pedals to keep the car loaded all the time.
Is the car at all loose on entry? If it's not, put more LR bite in it, that will free entry a little and give you more drive from center off. More info on your complete setup would really help. JMO
