A40s
  • 18 mod
    • Jun 2013
    • 7
    A40s
    Anyone else having problems with the 2nd tread in from the outside chunking out. It is only that row. After a 8 lap heat the tread raises and is spongy like the rubber is blistering at the base of the tire. By the end of a feature it has nearly the whole 2nd row chunked out. We are starting with 13-14psi and siping less than 1/8" deep. Seems that its worse when there is moisture in the track. Any thoughts/advice would be appreciated cause this is getting expensive.
  • erm11
    • 495
    Quit siping
    • George
      • Aug 2016
      • 9
      yep ,don't sipe, especially on fast tracks.. but you don't need to sipe A40S...maybe after 4 or 5 nights on a right rear
      • thinkstomuch
        • Sep 2013
        • 231
        not having these issues. agreed - i'd stop siping
        • RCJ
          • Nov 2007
          • 509
          Raise the air pressure a couple lbs.
          • jhill22
            • Jul 2012
            • 48
            Don't sipe
            • JustAddDirt
              • 1893
              I only sipe them if they harden up a bit, or I have moved them to the front of car.
              I would NEVER run one on the RR.
              if it run them on the LR new, I never sipe them.
              • powerslide
                • 2696
                what do one of these punch new?
                • JustAddDirt
                  • 1893
                  I have seen 40-50 new .
                  kind of a wide range.
                  • langdonracing48
                    • Dec 2013
                    • 183
                    Like everyone said, quit siping. It tears the a40s apart. Its also trash on the right rear anyway. Bolt on an H.
                    • JustAddDirt
                      • 1893
                      a40s
                      exactly.
                      The feel really mushy on the RR to me. car is real squirmy. I have only tried them on a slower track on RR and do not like feeling.
                      I Really like the H on the RR at all times. just have to know how to get them to fire quick.
                      • powerslide
                        • 2696
                        Originally posted by JustAddDirt View Post
                        exactly.
                        Even for 2 laps at the gateway nationals?
                        • JustAddDirt
                          • 1893
                          tires
                          maybe an exception there, especially early in night. I don't think that track will be really fast. but if it gets hard and slick, I would put on an H without a doubt
                          • Fox_hunter42
                            • 570
                            Hoosier told me to only sipe a new tire, less than 1/32 deep and only one time. helps the rubber to cure and harden. heat soak tire before racing it.
