Have a 11' rocket modified, pinto spindles 4bar/4bar with pull bar. My car is ill handeling. It won't get on the bars instead it squats like a street stock. Thinking pull bar any second opinions? Suspension all new less than 25 laps on everything (except pull bar) thanks everybody.
Car won't get on the bars
I honestly would have to check I know the lowers are flat. The upper I believe are angeled uphill but how much I don't know will check after work.
right lower ok to be flat
left lower needs to run uphill with you in driver seat at least 5º
how much pull bar angle, and what length, and spring or bushing?
What front clip?
what springs?
what are your bar angles setting at ride height?I think there should be lifeguards in the genepool.
All measurements taken at ride height. Left upper-19.9* right upper-20.5*Left lower-2.1* right lower-0.8*Pullbar- 41" 16.9*Bsb 3 stage pullbar has red bushings and hypercoil springMetric front end
If you jack the car up does it hit the chain or chains? How much drop out do you have on Lr? What's overall angle in LU bar at full hike?
I'm running integra shocks left side shock ahead spring behind. Right shock spring together in front. When jacking car up it will hit the chain limiter. Not sure on angle will have to check.
To achieve that angle extending the bars is the proper adjustment? Want to check to make sure the right adjustment is being made.
