Pullbar Mounting Location
  • Rogue1
    • Dec 2014
    • 33
    What effects will mounting the pullbar in front of or behind axle centerline on the rearend have?, currently 8" above housing and 1" in front of axle centerline
    It's always the cars fault
  • Lizardracing
    • 839
    The angle of the link changes and affects the anti squat properties when the axle moves around.
    When mounted behind the CL the link angle will lesson.
    When mounted ahead the CL will increase.
    • Team EERC
      • Oct 2012
      • 40
      More to this than I care to type give me a call and I can help you out. 573-330-8462
      EFR Motorsports / Team EERC
      www.teameerc.com
      erik@teameerc.com
      Contact: Erik Edgar
      573-330-8462
      6103 Highway DD
      Farmington Mo 63640
      • RW57
        • 662
        In front as rear rotates and car squats pull bar will not over center and lessen effect of rasing front of car and pushing tires into ground.In middle or behind it looses leverage decreasing lifting effect. Basically the same thing some else posted I am trying to put in layman's terms
