I am adding a rear mounted oil pump on a motor, on my little m block I just ran the line into the rear of the block, but I am using a stock 350 block. So i added a remote oil filter adapter and will be running the line into a oil filter block off plate, I am using Moroso 23840.
I am guessing this will work, as the motor is together and I do not want to drill into an oil passage and add a fitting.
Where do you all normally mount the remote oil filter? Not much room back there without running excess lines and the (not a nice word)(not a nice word)(not a nice word)(not a nice word)pit isnt stiff enough in my opinion.
How do you prime these pumps with the power steering and fuel pump hooked to it?
Thanks
Thanks
