Looking for opinions on these mounting points.
Notice Quick change is offset to right to achieve drive shaft alignment - this is based on Motorcycle engine drive line down right side - driver sits parallel to drive shaft.
Should Pull bar get moved to left so it is centered?
Would this be better than way far to right?
Same with pinion mount of J Bar - would it benefit from a centered mounting position vs. way over to the right?
Does the offset drive line effect the mounting points? Or would the mount points work better lined up on the drive line?
Thanks for opinions
Thanks for opinions
