American racer tires
  • tas96 amca
    • Mar 2011
    • 1
    Hi just wondering if any one is using inner tubes with there American racer 15x8 tires as we run these tires on our class AMCA here in austrailia and we cant run beadlocks , just wondering what every ones thoughts and what tubes to use ,cheers .
  • HEAVY DUTY
    • 796
    Run them tubeless.Get a good wheel, like aero or bassett. Bassett has an extreme bead wheel that holds the tire on real good. You almost have to cut the tire off to dismount.There are other tricks to hold the tire on like weatherstrip adhesive welding a taller bead on the wheel and rim screws if allowed.Guys used to put vineager or battery acid on the bead (bare metal) to make the wheel rust and stick the tire.Using a wheel with the wide lip out helps also.
