The engine oil to run
  • modracer18
    • Aug 2014
    • 56
    Just wondering what everyone thoughts are on the best engine oil to run on a usmts engine. I know there many different brands out there but im thinking about switching from the Vr1 that we run to see if i can get a little less wear on the engine.
  • langdonracing48
    • Dec 2013
    • 183
    Schaeffer's is the best oil for the money by far. Love the stuff. I change it every 6-8 nights, still looks beautiful and my bearings look great.
    • Crose6x
      • Mar 2015
      • 7
      Vrl has high content of Sulfated Ash in it. Very bad on engine wear we use Brad Penn when we freshen the motor the bearings still look new.
      • CoastieMod
        • 11
        brad penn has been great for me.
        • leadfoot_35
          • Jun 2008
          • 509
          I've always used Brad Penn and get good results.
          Josh Smith #35
          • powerslide
            • 2696
            If you are having a lot of wear you may look at the breather and the top on bottom pieces, a slightly bent or wore air cleaner base will let a lot of dirt in if you run dusty tracks
            • oldtrackchamp4x
              • 270
              Brad Penn. JMO
              • dereksehi
                • Jun 2013
                • 307
                I've had excellent results with the synthetic VR1 myself. What kind of wear issues are you currently having? What type of air and oil filter are you using?
                • modracer18
                  • Aug 2014
                  • 56
                  I freshen my engine after about 15 races and the bearing look a little more wore than usual but we ran on some dusty tracks last. Basically thinking about just trying something new
                  • oldtrackchamp4x
                    • 270
                    I run 30 or more races before i even think about looking at my motor and the bearings look great. As derekshei and powerslide said, i would be looking at air cleaner real hard. JMO
                    • powerslide
                      • 2696
                      How many races did you run the stuff you have been running?
                      • powerslide
                        • 2696
                        I would consider trying to change the filter each night and running oil 3-4 races. We were doing 4 races and everything looked fine but if you are having issues it MIGHT help but likely just a bandaid to another issue.
                        • oldtrackchamp4x
                          • 270
                          Might also think about plugging the bypass valve on your oil filter adapter if it isn't already plugged. JMO
                          • GRT62
                            • Jan 2014
                            • 177
                            Renegade oil is top notch also
                            • stock car driver
                              • 3233
                              buy gibbs oil and run it most if not all season for most guys who run 30 nights or less
