Originally posted by HEAVY DUTY
View Post
Chevelle clips????HELP
Those two changes have been advertised I wouldnt consider that completely different, that saves you a hour of cutting and plating. Until someone chimes in who has had their hands on one I guess we wont know.
I have a Really good Barry Wright chassis late model has very low laps, want to make a mod out of it. I have metric clip, was going to try and find a Chevelle. But like i said i think the metric id just as good. but a friend of mine wanted to put a chevelle on it what do you'll think?Last edited by hanginitout; 03-03-2017, 04:36 PM.The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
I'm still trying to figure out why a mod has to run these clips. There's nothing stock about any of it. Speaks volumes about the people writing the rule book!Shocks by BGR army
I agree, they seem so much weaker too. But it makes them feel good i guess. Somewhere GM has to have a jig in storage and the stamp.. but a properly configured tube chassis with the pick up point where they are supposed to be seem to be the best. Heck these cars are late model on 8" tires now any how. I think I'll go with the metric. What do you think ??? Thank you allOriginally posted by Brian Gray View PostI'm still trying to figure out why a mod has to run these clips. There's nothing stock about any of it. Speaks volumes about the people writing the rule book!Last edited by hanginitout; 03-07-2017, 05:13 AM.The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
They do have one,,Howe has a fab clip ready to weld on..all the correct suspension points,springs plated, and cleared.In fact if you want to buy a new Howe mod dirt or asphalt you need to supply them with a clip so they have something to add to there stock..I think they are tired of running the junk yards..It also has two locations sleeved on each side so that the weight is bolted into the same place on all of them to match that of a Chevelle.
I bet they will never approve that one. these after market chevelle clips are weak. not saying that they should with stand a huge crash but i was hit with a tire in the left front twisted the left horn down as if turning your arm.Originally posted by Wizard 05 View PostThey do have one,,Howe has a fab clip ready to weld on..all the correct suspension points,springs plated, and cleared.In fact if you want to buy a new Howe mod dirt or asphalt you need to supply them with a clip so they have something to add to there stock..I think they are tired of running the junk yards..It also has two locations sleeved on each side so that the weight is bolted into the same place on all of them to match that of a Chevelle.The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
The Howe clip HAS been approved at Some Michigan tracks that I know of..They are all looking to the future of not having any good old clips VS the cheap kits that can be tweaked any which way you want..They are all serial numbered as well. I also believe that Port City now offers a fab clip for mods as well.
Need to make there way south and west.Originally posted by Wizard 05 View PostThe Howe clip HAS been approved at Some Michigan tracks that I know of..They are all looking to the future of not having any good old clips VS the cheap kits that can be tweaked any which way you want..They are all serial numbered as well. I also believe that Port City now offers a fab clip for mods as well.The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
because it would obsolete thousands of cars with one stroke of the pen. I have an old DW11 probably built in 07 or 08 and i won races in it 2 years ago. These cars haven't changed all that much just the setups have.Originally posted by Brian Gray View PostI'm still trying to figure out why a mod has to run these clips. There's nothing stock about any of it. Speaks volumes about the people writing the rule book!
Technical inspection is costly, time consuming, overburdening.
Stock clips or not, without the ability to properly check race cars at the track after the race cheaply and easily any rules written anywhere for any class relies heavily on the honest racer factor. Money and pretige are the main factors on why we do this which opens the door to fudging the rules so whether aftermarket or tube clips the issue remains or even possibly gets worse.
GM didn't make the clips meant for race cars so some tolerance is already built in but I think asking a racer to leave it alone aside from removal of minor stuff will net a fairer result than asking the racer to build from scratch and build in all the compromises themselves. I don't feel like either is a good solution but I don't have a better one either aside from having one or two approved manufactures put these things together but that's going to raise the costs that are already having a negative effect on racing at that same time.
I would say, that i have to agree with you. After hearing it put that way. for good point.Originally posted by Lizardracing View PostTechnical inspection is costly, time consuming, overburdening.
GM didn't make the clips meant for race cars so some tolerance is already built in but I think asking a racer to leave it alone aside from removal of minor stuff will net a fairer result than asking the racer to build from scratch and build in all the compromises themselves. I don't feel like either is a good solution but I don't have a better one either aside from having one or two approved manufactures put these things together but that's going to raise the costs that are already having a negative effect on racing at that same time.The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
The crossmember has been narrowed up for radiator clearance, and the hump outside of the spring bucket has been flattened out for shock clearance.
Thanks, i heard they're pretty pricey too. I have a metric stub.Originally posted by amish119 View PostThe crossmember has been narrowed up for radiator clearance, and the hump outside of the spring bucket has been flattened out for shock clearance.The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
