Two blade fan ?
  • wallbangerII
    • 55
    Two blade fan ?
    modified on alcky does not get hot.
    how do you make a two blade fan?
    do you take a four blade fan apart? do you weld up the rivet holes?
    or do you cut two blades off and leave the center thick?
    THANKS FOR YOUR HELP wallbangerll
  • Renegade Cust Susp
    • 349
    Have done this before with GM style metal fan, drilled rivets removed 2 blades and ran. Just have to keep an eye on it, eventually it will crack at the river holes because of the flex.
    Broc Burton
    go.fast.crs@gmail.com
    • RW57
      • 662
      All I did was just cut off 2 blades the ones you buy that's all they do.
      • rangerover
        • Aug 2010
        • 41
        Same here. I took a new blade on the recip saw and carefully cut two blades off flush on a genuine GM fan. Been running it for 3 seasons with no problems and it pulls a ton of air.
        • Crose6x
          • Mar 2015
          • 7
          You can buy a two blade fan http://store.crateinsider.com/2-blad...ltiple-colors/
