Chain the RR
  • modracer18
    • Aug 2014
    • 56
    Chain the RR
    Looking for opinion on the best way to set the rr chain on a 2012 Grt. Ive never chain the rr what are some benefits of doing it. Thanks in advance
  • Keepittacky
    • May 2017
    • 9
    In our 2016 Grt we start an inch above ride height. As the track gets slicker we shorten it. This will tighten up exit quite a bit. Seems to keep more drive in the car as well.
    • rsawyers9
      • Mar 2009
      • 39
      We do the same on our 2015. 1 inch above ride height.
      • modracer18
        • Aug 2014
        • 56
        Thanks for the info rhat helps. Do you guys run more of 50/50 shock or easy up on the Left front. I usually run like a 9-2 but been thinking about trying a 5-4 or 5-5 i here it works well but never tried that. Thanks again for the info
        • Keepittacky
          • May 2017
          • 9
          Left front we usually stay with a 5-4. A 9-2 on the left front would be awful radical in my opinion. Left rear it would be fine.
          • bananahammack00
            • Aug 2016
            • 31
            What is the theory behind chaining the RR and then shortening when it dries out? Does the RR really lift the chassis that much? Keepittacky what brand shock do you run the 5-4 valving? Not all shocks are built equally....
              It is fairly common to lift the RR off the spring.
              • stock car driver
                • 3233
                rr chain adds tons of drive middle off when tight at ride height, but only works on smooth as glass tracks. if there are any bumps your tire loads and unloads as it hits the chain and that is BAD..
                • Keepittacky
                  • May 2017
                  • 9
                  We run bob Harris csi m90s they seem to be great. Have ran them for a year now.
