4 bar rearend trail
  • racer22
    • Oct 2016
    • 37
    4 bar rearend trail
    How much is too much trail either shortening the rr or lenthening the lr, i am new to the mod deal and have been pretty sucessful so far, i have won 2 features already this season but i have been kinda fumbling my way threw it. I was told that the right side being shorter will help the car from trying to step out off the corner. I have the rr 1/2 shorter than the left, could i go more than that.
  • stock car driver
    • 3233
    Usually trail or lead is referenced as the rr..
    so you would be running 1/2 lead
    Ive never heard of a person being able to run lead with a 4 bar modified or even a 3 link for that matter, with a 4 bar you can get infinite traction by changing the lr bars etc. Therefore rr trail is needed so the car goes around the corner vs shove the nose.
    If your cars working for you like it is make small changes after noting every detail of your set up now and calling that your BASE.
    • pig tracker
      • Feb 2015
      • 104
      Makes me think that maybe where he measures could be misaligned and not giving correct numbers. Just doesn't seem right. JMO
      • racer22
        • Oct 2016
        • 37
        I measured the links in the back, both sides were the same top and bottom, i shortened the right side bars 1/2 inch each side. If both the links are the same the rearened is square,
        • racer22
          • Oct 2016
          • 37
          Stock car driver, can you pm me, i have a few other questions if ya have time
          • pig tracker
            • Feb 2015
            • 104
            Oh. On my car there is designated spot that if both sides measure the same, the rear end is square. Of course, I never have ran the identical length bars on both left and rear. Sorry, sometimes I need to keep my thoughts to myself. LOL
            • stock car driver
              • 3233
              The rear end isnt square based on bar lengths... that is not accurate since they are NOT in the same holes side to side.
              You need to measure from the motor plate back to the rear end. I measured from my motor plate back on all my mods and squared the rear end at ride height.....
              Then took a 12 piece of tape measure cut off a old tape and put it on the front of the axle housing facing forward and scribe a line on the inside of my 4 bar bracket... so anytime on scale stands while rolling around under there on a creeper I could stick that 12 tape section up in there and see my exact lead or trail...... I had it so it took about a minute to measure every single ride height angle lead trail etc.
              I used angle finders, 12inch tape and cut a piece of metal to fit between axle tube and frame for rr ride height. I drilled holes in my frame above the front a arms so 3 was my base setting for ride on both sides.
              • 25jrjr
                • May 2017
                • 386
                I would first call the mfr. They usually put some kind of mark or tab on the framerails to square the rearend.
                I always liked to include the frontend settings with my wheelbase measurements. I establish a true chassis centerline off of the lower balljoints all the way back to the rearend. Then drop a plumb bob equi-distant from the centerline on each side. Then, measure from the balljoint to the rearend on each side, and you will have the wheelbase for both.
                • JustAddDirt
                  • 1893
                  how do you compensate for a clip that is turned with that process?
                  Also depending on amount of castor being ran that will roll the RF wheel back the more castor that is being used, which will skew the length?
                  lower balljoint or zerk fitting is not a true 0 line. it is pretty close, but not exact.
                  • 25jrjr
                    • May 2017
                    • 386
                    I only use it for reference. That way I always know what each side measures.
                    You sure about the caster. Positive caster increases the wheelbase.
                    I had a good friend who crewed on a truck team and their engineer used this method. This method is pretty complicated when you first try it, but it gets easier the more you do it.
                    • JustAddDirt
                      • 1893
                      ***depending on clip design***
                      IF you have a strut style car, (late model) or a rear steer ford clip car...
                      then you would lengthen RF wheelbase, because you adjust the front lower a-arm strut rod's length shorter, which increases castor, and wheelbase
                      On 99% of modified's, or equivalent, with a fixed lower a arm, you must adjust the top ball joint towards the rear of the car which shortens wheelbase to get more castor.
                      Guess it depends on which front suspension being used as to the method. (and since this is a Modified Tech Forum that is why I said it shortens.)
                      • stock car driver
                        • 3233
                        haha, positive caster makes the wheel base shorter.
                        your way of checking each side is a complete waste of time, all your measuring is the wheel base you can do that wheel to wheel with a tape measure, that side to side measurement has nothing to do with a rearend and lead or trail.
                        • 25jrjr
                          • May 2017
                          • 386
                          Way more to it than that, but I knew you wouldn't understand!
                          You must own the only square racecar ever built!
                          • stock car driver
                            • 3233
                            baha why the new user name?
                            if the front stub is turned and you do all your stupid measuring and your wheel base is equal side to side your rearend is not square
                            • 25jrjr
                              • May 2017
                              • 386
                              Duhhhhh....In school, did you fail reading comprehension? See post 10 above!
