What are ways to get more hike. Dw11 chassis, 4 bar. As stated before new to the mod class, what adjustments in general can i make to get more hike
lr hike
What do you mean more? If you lengthen your chain youll get more unless your running too stiff of a spring and its becoming unloaded but even then most likely with the right bar angles and index it will hike till it hits the chain with no spring, I know Ive seen a mod win a race with the lr slider all bent up and spring hanging free basically. didnt effect him much cus he was so smooth and didnt ever really let the car down off the bars
Running a 175 16" in the lr and a 175 13" in rr, running 30.5 degrees bar angle on the lr upper at rideheight, and 13 degree on the lower, i cant get any more angle out of the lower because im in the top hole already. My car currently does not have a chain on the lr, i am in the process of putting one on it. Generally speaking what changes promotes hike, more angle in the j bar? More angle in the links? Bite?
I would drop both left side bars. The top down 20-24 degrees and the lower to 4-8 degrees at ride height. I bet the excessive bar angle is causing the birdcage to bind and not drop any further.Bill W. and Dr. Bob......who could have known.
I agree with Confused?. Having that much angle in your bars is killing your hike/drop. Hold a pencil in front of you flat and let go of one end. Now, do the same thing but with the pencil at a 45* agree. The flat bar will allow the most drop, and the bar with angle walks forward instead of dropping. What's your reason for wanting more drop?
Question for Confused?
If the LR top bar is 20* at RH what degree should it be when the chain stops the travel?
I'm struggling with same issues as racer22. My top bar is 27 at RH and traveled to 47 when the chain stopped. Was this an issue?
