oil pump?
  • hipower17
    • 643
    oil pump?
    anyone use a stud to hold the oil pump on? i'm rebuilding a engine that has this just wondering i've never used this before what would the stud torque on and the nut that holds the oil pump on. thanks for any info.
    • 2020
    I'd be careful as I personally seem .001 difference in vertical rear main clearance between changing from a bolt to a stud if the block was align honed with a bolt. We always align hone the mains with a oil pump bolted on with the fastener that is going to be used.
    PS: that was a stock SBC block, just always installed when line honing after that so if an aftermarket block/cap it could be different and not have much effect but I don't know for sure.
    • Lizardracing
      • 839
      Agreed.
      I've had to go as far as using a stud when the threads pulled out because the bolt was too short. I kept adding torque 5 pounds at a time until the main bore was round again on a bore gauge. Ended up at 60 lbs ft I think?
      If in doubt, a local engine guy should be able to work it out as it's a simple thing to figure out when you do it all day every day.
      • racer69
        • Apr 2009
        • 249
        I use a stud on most of mine. You do have to be careful of length on some caps. I had one that would have bottomed threads out on the bearing! Other than that I have had no issues.
