Chunking rr tire
  • racer22
    • Oct 2016
    • 37
    Chunking rr tire
    In general, chunking the rr tire on a dry slick racetrack, what factors cause that, would i need to load the rr tire more?
  • JustAddDirt
    • 1893
    tire siped too much, or too deep
    too much heat.
    too much tire spin
    • npoole37
      • Sep 2008
      • 39
      Easier on the go pedal is the only fix I could find. I tried most all of it.. different sipes, grooves, loading the RR more and less, drilling small holes in the treads(needler), etc.. The only thing that helped was to "slow down".
      • a25rjr
        • 3774
        We had a similar issue several years ago. We determined the rr had too much weight. We raised both sides of our jbar and increased the bite 100 lbs.
        Turn LEFT, Vote RIGHT!
        • rsawyers9
          • Mar 2009
          • 39
          Overloading the right rear tire. Either from too much load or too much throttle input. If you think you are modulating the throttle correctly, try taking some angle out of your j bar. Get the car back to a more neutral position and you will improve your corner speed in the slick enough to gain traction coming off.
          • oldtrackchamp4x
            • 270
            Air pressure might be too low. JMO
            • Dirtracer50
              • 140
              Maybe a dumb question but are you getting a heat cycle or two on the tire before running a feature on them? We always try to put a couple hot lap sessions or heat races on a right rear before running it in a feature.
              • CCHIEF
                • Jul 2014
                • 399
                Cut too aggressive, sliding ass or loose , too soft a compound for conditions.
