i have owned 2 brinn trannies and both leak out of the tail housing..have even bought their driveline yolk and not fixed the problem. anyone else have the same issue??? we use atf
brinn tranny leak
Are these New Transmissions ? Has the rear seal and bushing been replaced? Just trying to get more info on these trans. There is also a Serial # stamped in the top of the main case and the top of the Tail Housing Flange to help see how old these are. JackOriginally posted by brett4 View Posti have owned 2 brinn trannies and both leak out of the tail housing..have even bought their driveline yolk and not fixed the problem. anyone else have the same issue??? we use atf
What kind of vent line do you have venting the transmission? if it is building heat, and pressure it has to go somewhere. or is it possible it is leaking out the vent?
I ram Brinn's for years, and never had an issue.Last edited by JustAddDirt; 01-29-2018, 11:14 AM.I think there should be lifeguards in the genepool.
Its just a rubber hose with fittings that can be fastened up higher in the tunnel for the guys that are blowing fluid out the breather.Originally posted by JustAddDirt View PostWhat kind of vent line do you have venting the transmission? if it is building heat, and pressure it has to go somewhere. or is it possible it is leaking out the vent? I ram Brinn's for years, and never had an issue.
