Crane distributor problems
  • dirttrack87
    • 927
    Have a 1510 crane (FAST) distributor. Takes 3 wires two are your normal purple green to msd box. Red goes to 12v ignition switch. Problem is I keep blowing the distributor circuit board. It will run then quit. Everything wired correctly, has anyone had this problem? Does the engine need to be grounded to frame?
  • CoastieMod
    • 11
    Yes the engine must be grounded to the frame. I had problems burning up temp gauges by having a loose motor mount. Check all of your mounts and make sure they are clean.
    • SRXSRULE
      • Jan 2011
      • 217
      YES, run a ground strap from the engine to the chassis. If you run an alternator also run a ground from the alt case to the chassis. Voltage regulator and ignition modules will not survive with poor grounds.
