usra bmod set up
  • powerslide
    • 2696
    I did a did the shock on the arm when i had a bmod. Your milage may vary. I also only ran about a 200, the motion ratio says thats really soft. But with all the stacks on LR 4bar stuff trying to make it soft as possible i'm not sure i was that far out to lunch
    • Rockinduramax
      • Sep 2018
      • 1
      How much angle is needed to run a swing arm?
      • powerslide
        • 2696
        Depends how long it is(thats what she said)
        start around 18 degree on LR
        • racing_kid
          • Sep 2012
          • 127
          My 3 link mod has 15 inch bars spring Infront shock behind lr 175 on top shock in front 20 inch pull bar 3 inch ahead of center line, the pull bar was a night and day difference in the slick from 3 inch behind to 3 inch ahead
          • racing_kid
            • Sep 2012
            • 127
            Lr 43 degrees at drop with 4.75 in of drop and rr is10 degrees at ride height
            • cgs
              • Jan 2009
              • 91
              thanks again guys. won again Friday night!!
              • powerslide
                • 2696
                Hell yeah congrats man they aren't easy to come by
                • cgs
                  • Jan 2009
                  • 91
                  Originally posted by hpontap View Post
                  One of the worst mistakes I ever made was to make too many changes at one time. If you increased you LR bar angle, I would try that and see what it does before changing anything else. One change at a time so you can see how the car reacts.
                  Ya I just did that Saturday night. won Friday at one track and Saturday night went to another where it was their championship night. no heat races, just a main. needless to say I over thought it and threw all sorts of adjustments at it. no I know what not to try when I go back for their open show next weekend!
                  • dirtracer07x
                    • Aug 2014
                    • 101
                    if running the soft lr preloaded do we need to go up on the rr? currently running a 150 lr and a 125 rr. Thinking about trying a 125 LR and a 175 RR. We have been playing around with the pullbar long and flat (10*) and has been working well. Anybody try chaining the RR down? Heard this will give tons of bite but is easy to mess up and go to far.
