engine question
  • hipower17
    • 643
    engine question
    will a bbc oil pump fit a sbc?
    • 2020
    Yes, you just need to use the shorter oil pump shaft made to do that and the correct pick up tube size (3/4")
    • bob75
      • 2814
      I didn't have to change oil pump shaft just bolted pump to cap. No issues
        • 2020
        While possible^^, you need to check shaft clearance with the dizzy installed. I am thinking the adapting shaft is .135 shorter, because a std length shaft and a BBC pump can have negative clearance and actually push up on the dizzy and cause the dizzy to lock up and strip the gear to the cam. Been there and done that, so be sure to check it has slop when installed (fully assembled and oil pan off to be able to see if oil pump shaft can move up and down and isn't tight/jammed).
        • Krooser
          • Nov 2012
          • 3117
          Depends on deck height and if the manifold has been machined
          Class of 2019
