Carb problem
  • pro4
    • Nov 2008
    • 30
    Carb problem
    Running 4412. When car is hiked up and going through corner on the RF as the car is at an extreme angle and g force the car blubbers bad and won’t clear out until 3/4 down straights. How are you guys adjusting floats for this and or what do you do to fix this? Thank you
  • Jking24
    • Oct 2017
    • 1512
    You may have to much fuel pressure. But aside from that a tapered carb spacer if allowed. If not the only real way to combat it is lowering float level. That being said if the first and last thing mentioned are correct it's usually not a problem
    • 95shaw
      • Nov 2007
      • 205
      I have had the best luck lowering fuel level to a sixteenth or so below the threads in sight glass.
      make sure you have the vent baffle/ extension on there.
      • JustAddDirt
        • 1893
        tilted carb spacer
        lower float levels
        tilt motor down in back, and lean motor to left.
        connect the 2 vent tubes with a piece of clear tubing, and make a hole in the top to vent them.
