Best pullbar
    We had to do some cutting........and welding to make it work!
    • MODRACER18B
      • Sep 2018
      • 6
      Thanks guys for the replies. I have looked at the Nueline stuff has anyone ran any of there products?
      • Mr.Kennedy777
        • Aug 2016
        • 212
        The best pullbar is a lift bar.
        Not true at all.. We drive circles around lift arms steady and can keep our pinion angle a lot closer to a lift arm these days than you'd think. I will also add, we can also do stuff with a pull bar that you just can't with a lift arm. That's about all I will say though.
          • 14303
          I have no question you can do some things to help geometry with a pullbar. Geometry on every component of a dirt car can still be improved.
          That said, if you don't wind up with something where the gas pedal has less influence on antisquat, than a lift bar, you haven't made a better mousetrap from the standpoint of corner speed.
