Lightweight Wheels
  • badfast47
    • 139
    Lightweight Wheels
    Having these on the car help ? Thanks.
  • 95shaw
    • Nov 2007
    • 205
    Old school of thought was always any weight removed from unsprung was good. Weight removed from rotating weight also good.
    However, with some of the new thinking, use of weight at theses positions can be used to tune chassis and control traction/wheel acceleration. Some rules do not allow adding weight to axles, or weighted wheel spacers, so wheel weight becomes obvious choice. Some rules require stickered wheels, or minimum weight rule for wheels.
    So, if are unable to spin the tires, and chassis working perfectly all the way around the track, light wheels are an advantage.
    Next thought would be bang for the buck.
    • badfast47
      • 139
      ( Some rules require stickered wheels, or minimum weight rule for wheels.) Not a prolem where i run.
      • badfast47
        • 139
        Now if it is good to have lighter wheel how much weight is needed to be dropped say from a standard 31lb. Beadlock wheel for example, to make a difference ?
        • 95shaw
          • Nov 2007
          • 205
          Depends on what you call noticeable.
          Put a standard wheel in place of the bead lock. That should be obvious, and not likely to drop more weight than that from a bead lock.
          The results should be better acceleration, and better wheel control from shocks and springs.
          • badfast47
            • 139
            Last sentance was what i was looking for. Might be able to drop as much as 8lbs. on the RF and 4 to 5 lbs. every where else. Thanks for the help.
