camaro lower on metric frame
  • riddle28
    • Apr 2010
    • 1088
    will it fit without having to move the fame mounts?
  • 95shaw
    • Nov 2007
    • 205
    Gen 1 camaro/nova lowers will. From rear steer cars.
    Gen 2 camaro are the same width as Impala lowers.
    • riddle28
      • Apr 2010
      • 1088
      so like a 75ish camaro like the guys use for street stock cars wont fit a metric monte carlo frame without moving the frame mounts?
      • 95shaw
        • Nov 2007
        • 205
        That is correct.
          Back in the late model stock days, we would whack the ears off the lowers and weld a flat plate in its place. Then drill a 1/2" hole in it and install a heim in it. Then you can adjust wheelbase and even caster/camber.
          • riddle28
            • Apr 2010
            • 1088
            Originally posted by 95shaw View Post
            That is correct.
            thanks for the info
