I was just wondering if anybody has any ideas, ive got a mild all steel wet sump motor. All star fabricated valve covers. We turn about 6500 and it’ll blow oil out of my breathers. We do all our machine work and I know the cylinders are straight and good finish, this is the 2nd set of rings I’ve put in thinking maybe the first set didn’t get seated right but hasn’t made any difference. So now I’m leaning towards the top of the head is not draining back fast enough and it’s causing it. I was just wondering if anybody else has ran across this and found a solution. Thanks
Oil blowing from valve covers
Swap valve covers with a set you know didn't blow oil. If those covers have too small an air way or baffled too much, it makes the air come out at high velocity and carries oil vapor with it. The oil then puddles in the breather and drips out. Also put breather at the top of tube so any oil that does make it there can run back down tube, I see many people but the breather too low so the tube sticks up in the breather making it catch oil and has to drain out of the breather.
Also check if no baffles or just a large hole that it isn't directly over a rocker push rod hole or something that is squirting oil up the hole/tubeLast edited by billetbirdcage; 03-14-2021, 09:08 PM.
thanks billet ill try that. after hot laps it was completely dry and after the heat race it had some drips. i figured its a fine line between having the tubes too restricted vs not enoughOriginally posted by billetbirdcage View PostSwap valve covers with a set you know didn't blow oil. If those covers have too small an air way or baffled too much, it makes the air come out at high velocity and carries oil vapor with it. The oil then puddles in the breather and drips out. Also put breather at the top of tube so any oil that does make it there can run back down tube, I see many people but the breather too low so the tube sticks up in the breather making it catch oil and has to drain out of the breather.
I have run both cover without breathers at all. Closed covers and move one breather to the middle of the intake and vent the case in the valley instead. There is usually engough room between the carb and dist for a 1.5 NPT or O-ring fitting and 2" long hose to connect a breather. OR run that hose to elsewhere like behind the Midplate. There is more room in there, slower moving air-oil, and no worries about the stupid hole location being right on top of the rocker so oil is sent right up the tube.
Its works great.
We had a valve cover issue similar to what billet described. We couldnt figure it out, so we loosely folded a blue shop towel and stuck one in each breather. We changed them out every week, but it was a very mild issue. Problem solved.....cheap!
00 steel wool. Cut in, and pull it apart a bit so air will vent through. Insert it down the valve cover tube. The steel wool will keep the oil droplets low in the tube and not letting it flow up and out of the breather
Just something that I done when I was pulling my hair out at certain race tracks that I would have an issue with oil out the breathers.I think there should be lifeguards in the genepool.
Are these rubber baffles designed to go into the tube of the valve cover or do they bolt into inside it?
Picture or link?
I'd never heard of rubber ones so I'm just curious.
i run the fabricated all star valve covers, the baffle that comes in them is basically just a flared freeze plug. i drove the freeze plug out and push these down in the tube
