Chevelle stub 3 pc spindle ball joint question
  • 44xForever
    • Aug 2020
    • 15
    Does anyone know what ball joint is needed for stock chevelle lower control arms with allstar 55970 and 55971 3pc pinto spindles? they say they use stock metric ball joints but I don't have metric lowers....Also is IMCA so alot of modifications are out the window. Thanks in advance
  • TS3g
    • Oct 2007
    • 201
    Most run a K6117 as it fits the Chevelle lower hole perfectly, and doesn't require reaming of the spindle. One like so:
    https://www.performancebodies.com/pr...t-k6117-200381
    If you want a little shorter ball joint, you can get a hybrid that uses the K6117 housing and a K6141 stud. Reaming might be required to get the stud up through the spindle far enough to get a cotter key in. One like so:
    https://www.performancebodies.com/pr...er-ball-joint-
    Howe, AFCO, Speedway, Lefthander, etc ball joints are legal in IMCA also. Just make sure to weld the housing into the a-arm
    • 44xForever
      • Aug 2020
      • 15
      TS3g Thank you for the info! much appreciated. I will have to check the spindle on the right front, the original ball joint that was in it had a .300 spacer under the spindle the ball joint went through. I dont know if it was there to adjust roll centers or if it was just to help with a worn spindle. May need to look at a shorter one for the RF depending. Thank you again for all the help!
      • 44xForever
        • Aug 2020
        • 15
        Would you happen to know if you can use the 5/8 stud mounts and heims on the center link for the inner tie rods instead of regular inner tie rods?
        • TS3g
          • Oct 2007
          • 201
          Weird on the spacer, not sure what to tell you about that.
          No, you cannot run heims as inner tie rods in IMCA. Most run the 4" long Corvette inner tie rods with the ends drilled for a grease zerk. Wehrs and Outpace both make really nice extreme clearance tie rod assemblies for the RF.
          • 44xForever
            • Aug 2020
            • 15
            Good to know. Thanks for that too.....this car was ran in IMCA in Maquoketa, it had the stud set up, but I was fairly certain that wasn't legal most places. I will look for the extreme clearance set up today. Thanks again for the info. Looking at a Rule book is one thing, but seeing what is done is quite another....everyone wants to act like it's trade secrets these days lol
            • Lizardracing
              • 839
              Since 1997, Wehrs Machine & Racing Products has been innovating the finest products in the racing industry. A circle track parts manufacturer specializing in suspension components, tools, technology, and more. We also manufacture the Ultra Force spring smashers and developed the Ultra Force suspension software which allows you to take your program to the next level. Proudly made in the USA, champions across the country choose Wehrs Machine to take them to victory lane.
              • 44xForever
                • Aug 2020
                • 15
                Can you use this with a drop or bent outer instead of a straight outer rod?
