Looking for some input on how anti squat is achieved in a 3-link rear end. My guess is more angle in the lower trailing arms or more compression on lr shock. My issues is with adding more angle to the lower bars, especially the left side, you will gain a push and tend to lift the left front tire. Less wedge needed if you run more angle in bars? Thanks for any input, trying to keep the car from squatting on the straightaway
3-link anti squat
More shock compression isn't really anti-squat. It can keep it from dropping as fast when anti-squat is lost.Originally posted by Sanders46 View PostLooking for some input on how anti squat is achieved in a 3-link rear end. My guess is more angle in the lower trailing arms or more compression on lr shock. My issues is with adding more angle to the lower bars, especially the left side, you will gain a push and tend to lift the left front tire. Less wedge needed if you run more angle in bars? Thanks for any input, trying to keep the car from squatting on the straightaway
Anything you do that results in a higher lr, under throttle, will make the LR carry more weight. This will make the car tighter on the throttle.
To combat this, you can add static rr, add rr spring, move pullbar right. All of these have other consequences.Modern Day Spec Wedge Racing
Thank you for the replies. So is left rear bar angle the true way to have anti squat? Have the spring right but from pst experience adding angle to the left rear makes car prone to lifting lf also. Aside from adding static right rear and adding rr spring, could I also add right rear bar angle? Seems like that would drive the right side of the car up, driving the left front down and also loosen the car back up after getting tight from adding left rear?
Lr bar angle is lr anti squat. Rr bar angle is rr anti squat.Originally posted by Sanders46 View PostThank you for the replies. So is left rear bar angle the true way to have anti squat? Have the spring right but from pst experience adding angle to the left rear makes car prone to lifting lf also. Aside from adding static right rear and adding rr spring, could I also add right rear bar angle? Seems like that would drive the right side of the car up, driving the left front down and also loosen the car back up after getting tight from adding left rear?
When lr gets high enough, the lf is coming off the ground unless you get the rf lower or the rr higher.
Keep in mind, if you get the rr too high off the spring, it's going to be a handful when you get to the corner.Modern Day Spec Wedge Racing
