LR spring rates
  • outlaw4j
    • May 2012
    • 72
    LR spring rates
    looking for some pro's con's to light vs heavy LR spring setups
    we have been on a 150# and its good when its good but doesn't seem super consistent. Our setup overall seems a bit hot or cold especially on corner entry (tend to get tight first)
    we want to try a change here just not sure if its better to go lighter and more preload, and heavier with less first
    • 14303
    1) your spring should always have load on it.
    2) find the extended load where your car works best entering the corner.
    3) leave it alone
    • outlaw4j
      • May 2012
      • 72
      3) leave it alone
      This is the part we struggle with i think, balancing on / off throttle entry. We seem to not need much preload for on throttle, but then struggle off throttle. In my head it seems the heavier spring would help more here.
      Like we are good on sweeping tracks, or tracks with banking, not so good on paperclippy or slower entry tracks, then ok if we can use enough rear brake to cheat
      • Kromulous
        • 3008
        How much are you traveling the LR spring? or how much Drop?
        Just say no...
        • outlaw4j
          • May 2012
          • 72
          right now we are @ 4" drop
          • Kromulous
            • 3008
            Ok, our current chassis is traveling 6" but its to much, we had a Pierce car (we should of kept LOL) and it was around 4.75" with zero index. Think I will cut it back and try something in the 5's
            Heavier or Lighter Springs i dont know of any difference. I know some guys are running 50 Lb spring, around 100 to 150 lbs droop load, then resting on a bump at ride. No idea if one is better than the other. I guess its a trial and error deal.
            A lot of it is in the shock, Ive seen some Insane Compression numbers when running a 50lb spring.
            Just say no...
            • outlaw4j
              • May 2012
              • 72
              yeah if we run much more than 4.5" ish we start to get real tight, back of the car feels good but have a tough time getting it to turn. I think its the added jbar rake.
              we probably are in that 100-150# load # most of the time as well. We have a 1/2" preload on a 200# for the weekend. will see how it goes
                • 14303
                When you are off the gas, LR load rotates the car. The only thing that matters is the load when you are asking the car to rotate. The stiffer spring will pick up load quicker, as the car settles, but that's no good if it leaves you with too little when you need it.
                • outlaw4j
                  • May 2012
                  • 72
                  yeah i think this is where i get confused on the LR...
                  earlier this year at a track that was new to us we struggled the first half of the feature being tight on entry. then all of a sudden the car took off and we started driving through the field. after the race we found the lock pin on the LR slider had came loose and the preload nut backed off taking almost all of the preload out.
                  But if we try to run that really low preload at the short tracks the car doesn't like to stay up and is super inconsistent.
                  we don't want to use LR as an adjustment as honestly i don't even understand the why completely, so we are trying to get this area of the car more consistent so we can figure out what other adjustment we need to make at the track to affect entry better
                  i also struggle with if we need say 200# of load, what is better a 200# spring @ 1" or a 100# spring @ 2".
                  • outlaw4j
                    • May 2012
                    • 72
                    well we ran the 200# in LR Friday. Unfortunately we got caught in a pretty good wreck and ended the weekend early so didn't get a full run on it, but car was nice and free and we were going forward.
                    Need to get a full run on this set, then we are going to put a 100# in and see what the difference is
                    • outlaw4j
                      • May 2012
                      • 72
                      ran the 100# setup last night. set load on it to match scale #'s, ended up being a couple inches of preload in it at drop.
                      id say it definitely made off throttle corner entry better (more consistent). but we were definitely tighter on throttle entry.
                      we were maybe faster on the 200# than the 100#, but 100# was easier to drive and with some secondary adjustments might be pretty nice. the 200# was faster but is very particular and we would be to free and too tight sometimes
                      going to roll here the rest of the weekend with the 100# and see if we can dial it in more
                      • Kromulous
                        • 3008
                        Throttle entry, that intial turn on while not getting out of the fuel?
                        Sounds like its keeping more drive in the LR longer down the straights.
                        Ive noticed this when i added more drop out load (LOL at the different names, i call it droop load) Im right at 200 lbs with a 100 lb spring as well. It makes good exit traction but at the end of the straight he has to get out of the throttle to get the car to turn, and that aint fast.
                        A mix of the two i guess is what we need.
                        Just say no...
                        • outlaw4j
                          • May 2012
                          • 72
                          On throttle entry yes up to a point just past phase 1, then we have to get out of the gas to get through the middle. Nice part here is so far its the same whether the track is heavy or slick. Have to start turning early before every getting out of the fuel. at least thats how its working for us. As soon as we roll out it starts to turn. Running 4.5" of drop.
                          Had an interesting one last week where we had a real heavy wettish track in our heat race and won by almost a straightaway. For our feature the track actually tractioned up and we got super throttle tight, but entry stayed really good.
                          we actually also put in a little more chassis side jbar and got a little better feel on what car is doing on entry.
                          we are off this week for other commitments but are going to back off on a couple of the traction changes. not sure yet if we will stick with this or not but the consistent entry is so far a nice addition
                          • outlaw4j
                            • May 2012
                            • 72
                            after a run with the soft LR we ended up going back to a stiffer one. the soft LR was really good with off throttle entries but was a bit to inconsistent for us in all on throttle applications.
                            the stiffer LR is much better for us on throttle entries and on throttle in general.
                            was fun experimenting with this and even though we dont understand it all, we at least understand what it is doing / not doing for us.
                            had a good run friday and had a bad break in lapped traffic and then won on saturday night.
                            • Kromulous
                              • 3008
                              Soft LR was really good off throttle, how so?
                              Just say no...
