I've been fighting a major push on entry for awhile now and need help.Car seems to behave the first 2 laps or so then develops a major push on entry that'll put you into the wall. Doesn't matter if you are on the gas, trail braking in, or hard on the brakes. It'll only turn after the car slows down a lot or stops. The only time where it has handled somewhat well is when the track was really hooked up. Still had a push but not as bad. Next weekend went out to practice and it was a little greasy and it pushed bad. I've changed RF spring, tried different LR shocks, played with the J-bar, 4-link bar positions etc. I can feel them all tightening and loosening the car but it still won't turn after a couple laps. Last race found frame is hitting the track.Track configuration is 1/4 mile high banking.Car Info: (2016 Dream Chassis Chevelle Clip, Supposedly a GRT Clone)Open MotorCar Scaling: 15 gallons fuel (No Driver, Driver is 150lbs)LF 591 RF 498LR 712 RR 641RF Shock BSB RF1-75LR Shock BSB LR1-40, 400 BV RR- Trail Currently 1 1/2" (Was 3/4" still same issue)Tire Stagger:LF 80 RF 82---2" StaggerLR 81.25 RR 83.5---2 1/4" StaggerSprings:LF 550 RF 500LR 150 RR 175LR 200lb Preload at full Droop (On the chain)Any help greatly appreciated.
