LF Bump stop?
  • Kromulous
    • 3008
    LF Bump stop?
    Not sure if anyone will share any info on it or not, but whats it do ? I see them a lot nowadays.
    I would think its so you could run a softer spring to help get the Car to steer, but then not fall off a cliff if you get out of the Gas real quick but i never ran one to know.
    Just say no...
    • 14303
    It's about having two different rates and a reliable stopping point. Reasons can include wanting a soft spring to aid weight transfer upon acceleration, soft rate on initial turn-in as you suggested, or probably quite a few other uses. It can actually be easier to tune entry with one, IMO, especially where you slow a lot before entering the corner.
    • Kromulous
      • 3008
      Soft spring to aid weight transfer upon acceleration. Hmm thats interesting, i need to study on that i guess.
      I guess i need to get one on and start tinkering with it LOL.
      Just say no...
        • 14303
        I'd say the weight transfer deal would not be a modern use. Back in the leaf and early 4 bar days, guys would run dual rate across the front to have a light rebound rate for maximum weight transfer. You could drag race like nobodies business. Entry was another story...
        • JustAddDirt
          • 1893
          Back in 2018 i played a bit with 5" X11" springs 250-275# left front 225# RF on a chevelle clip modified.
          had a bump stops on both front shocks.
          at lawrenceburg it would coil bind the RF because of the waves, woop sections in the track.
          • 95shaw
            • Nov 2007
            • 205
            It is still the same as the left rear, using a soft spring maintains more weight on the tire for the same amount of travel.
            100# spring
            600# load.
            Unload 200#. Spring is 2 inches longer than at ride height.
            600# spring
            600# load
            Unload 200#. Spring is .333 inches longer than at ride height.
            For a given travel, softer spring maintains more load.
            For a given unload, softer spring travels farther.
            Raising the center of gravity is generally synonomous with weight transfer.
            • Kromulous
              • 3008
              So your saying in simple terms that the LF Spring can retain some weight longer with the lighter spring, makes since.
              A 275 and 225, thats crazy.
              Just say no...
              • outlaw4j
                • May 2012
                • 72
                after watchinq a few usmts races this year i think they might have the bump stops on the LF to act as litteral bump stops. a lot of them dropping pretty hard onto the LF on entry
