shock mount placement?
  • nwdirtracer00
    • Feb 2010
    • 7
    I am changing over my GRT metric front end to a Nova one and have a question I
    hope someone can answer. I know what side goes on where, I am not sure if there is
    a certian angle or placement of the shock mount on the nova lower? I hope someone out there has gone through this and can help me out.
    Thanks in advance
  • BMOD6
    • Jan 2009
    • 204
    shock mount
    The main critical thing on a mod is clearance on the upper and the frame. You would want the lower shock mount as close to the ball joint as possible. The farther away from the ball joint you put it the more shock force it would take to do the same job. At the joint you could install a 4 shock but an inch and a half away you may need a 5 shock. I hope this helps some.
