Rearend/drive shaft alignment help.
  • Kojak_9x
    • 179
    Had to replace the 9'' Housing in the mod (4/4) I'm drivin this year.....It is 1'' shorter on the Left (drivers side) tube.... Do I align up the left side tires with the same off set wheel? I did that but I have a 2'' side angle in the driveshaft lookin from above... Should I ??????
  • racin6mod
    • 2172
    I'd say aline the drive shaft and change the lr wheel and or add a wheel spacer.
    • Kojak_9x
      • 179
      Thats what I ended up doin tonight.... Thanks for the reassurance/help....
      • BigBlueFord
        • 189
        You'll also need to check your birdcage positioning and bar alignment on the LR. Basically the birdcage should be 1" closer to the brake rotor than what is was with the longer tube.
        Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
