DW-11 Help needed!
  • JR. MECHANIC
    • 253
    DW-11 Help needed!
    I'm looking for input on the pull bar location on an 2008 DW-11. It has the option of running the short pull bar that mounts basically next to the drivers seat and also the option of running it up to the driveshaft loop. My concern about running the shorter pull bar is that it seems to be running quite excessively to the Left front corner. thanks
  • not clamped up
    • 287
    If its a 4bar car I would put it in the center,when its mounted to the left is far to unpredictable.
    • JHobbs26
      • Aug 2007
      • 146
      I would NOT run the short pullbar unless you want to be running over your driveshaft when that frame mount pulls out. 2 cars we had back in 2005-2006 had this happen to both of them. The 05 car we took back to DW and they fixed it and it pulled back out the very first race we ran it.
